Grinding noise
  • 3433 Views
Offline maxamy
Grinding noise
« on: October 30, 2011, 10:18:25 AM »
I have a terrible "grinding sound and feel in my front end...kinda feels like drivers side but not real sure....I suspect a bad wheel bearing but I don't want to start forking out money and replacing parts plus a special tool I have to buy, without being sure....What is the best way (if possible) to test for a bad wheel bearing without removing the wheels, hubs, rotors brakes...etc..etc ...
1995 Geo Tracker LSI...16V 1.6L MPFI...5 Speed...4X4...Air,PS,PB...Blah Blah Blah... lol
1995 Geo Tracker LSI, 5 Speed, 4X4, 16V 1.6L, Soft Top Air,Power Steering Power Brakes
Re: Grinding noise
« Reply #1 on: October 30, 2011, 12:54:26 PM »
Jack the car up & spin the wheel - if you have manual hubs, unlock them.
Offline sport96
Re: Grinding noise
« Reply #2 on: October 31, 2011, 10:31:48 PM »
Also with the zuki jacked up , grab the tire at the top and bottom and shake,move the tire up and down then grab the wheel on the side and try to move it side to side. If you see or feel any movement at the wheel bearing area then you probably need a wheel bearing.
The wheel bearing should not move in any direction and when spinning the wheel it should not make any noise. Growling noises are bad. If you turn left or right, and the noise gets louder one of the ways, when your driving your zuki, the nosiest side probably has a bad wheel bearing.  Brakes also make noise sometimes but hopefully you can tell the difference, I am sure you can :)
I hope this makes sense, Halloween and all I have been drinking adult beverages. :)
Re: Grinding noise
« Reply #3 on: November 01, 2011, 05:35:24 AM »
My experience has been the reverse - noisy when going left is a bad rightside bearing & vice versa - the turn causes weight transfer in the opposite direction and the additional weight makes the noise worse.
Offline talonxracer
  • 1284
Re: Grinding noise
« Reply #4 on: November 01, 2011, 11:46:00 AM »
I had a bad stock locking hub(GM version not aisin) and it made alot of noise
Offline maxamy
Re: Grinding noise
« Reply #5 on: November 01, 2011, 06:00:11 PM »
I figured it out...It was bad bearings for sure....I took the wheels off and axle hubs apart and the bearing pieces fell to the floor....They disintegrated ...iccckkk... I am shopping for parts while waiting on my axle tool to come in that I ordered... Should have it up and running by the weekend....I also have to change a torn cv boot that I found while inspecting bearings....Joy joy joy....I'll get it fixed just in time to take it out in the woods and tear it up again.....lol
