GV or XL-7 Front Axle Housing
  • 14 Replies
  • 9209 Views
Offline WillyO
« on: August 19, 2010, 10:05:52 AM »
I know the XL-7's front axle housing is almost identical to my '96 TracKick's front axle housing (except that it's steel) and can be bolted in. I also know that the Grand Vitara's 3rd member will bolt into the XL-7's housing and has the same mounting brackets as the TracKick, making the XL-7 housing/GV 3rd the natural upgrade to the TracKick's weak aluminum front axle housing.
I've located a complete '02 Grand Vitara front axle assembly (steel) for $100. I'm buying it for the 3rd but would like to know if the housing is the same as the XL-7 housing?
'96 Geo Tracker 2D 4x4
1.6L 16v I4
5sp manual
5:12
Mods:
2" body lift (TJ Kit)
1.5" Front Suspension Lift, 2" Rear Suspension Lift (Low Range Offroad)
Specialty Products EZ Cam XR +/-1.75 Camber Bolts (HorsePower Freaks)
Thumb Throttle (Homemade)
16x6.5 Steel Wheels ('00 Grand Vitara)
Goodyear Wrangler LT245x75Rx16" M+S
  • 6593
Re: GV or XL-7 Front Axle Housing
« Reply #1 on: August 20, 2010, 07:43:36 AM »
Both of the housings XL7 and GV are the same as far as mounting and overall dimensions, they're just in steel instead of aluminum. The third member on a manual transimission equipped GV is steel as well and is a direct replacement for your Sidekick/Tracker. From what you've found, I think you could bolt it in as one unit with no mixing and matching required. The XL7 third member is similar but has a thicker "snout" and is mounted a bit differently (it is better). To make it work in your Sidekick/Tracker, you need to get the mount from the third member to the cross member from the XL7 and then you can bolt that whole assembly in.
Hope that helps.
Offline WillyO
« Reply #2 on: August 20, 2010, 09:23:37 AM »
It does Eric. Thank you... alot. But I do have a couple of clarification questions.
You said the 3rd on the manual GV was steel. Should I assume that means the auto GV version is aluminum? Also, are the housings from auto equipped XL7/GV steel or aluminum?
Thanks for the info on the XL-7 3rd mount. I'll squirrel that in to my "future mods" file. ;D
« Last Edit: August 20, 2010, 09:55:36 AM by WillyO »
1.6L 16v I4
5sp manual
5:12
Mods:
  • 6593
« Reply #3 on: August 20, 2010, 12:53:52 PM »
Auto GV = Aluminum
Manual GV = Steel
Early Auto XL7 (pre 2003)= Aluminum
Late Auto XL7 (post 2003)= Steel
Manual XL7 = Steel
2003 is a crossover year and I've seen both steel and aluminum in the autos.
Offline WillyO
« Reply #4 on: August 20, 2010, 03:04:07 PM »
Thanks for the info Eric.  :)
1.6L 16v I4
5sp manual
5:12
Mods:
Offline sir lance
  • 342
  • I love my XL-7
« Reply #5 on: August 21, 2010, 12:19:35 PM »
i will confirm with Eric, the front diff i pulled out of my 2002 auto xl7 was aluminum, 5.12 gears.
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« Reply #6 on: August 21, 2010, 07:47:45 PM »
Now that we got that taken care of, what models had the 5.12:1 gear ratio ?
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline bush buster
  • 263
« Reply #7 on: September 20, 2010, 05:36:07 PM »
I couldn't find a steel diff in my town so I ordered one from the US which I was told came out of a 2003 auto XL7. It is aluminum.  >:( So either it was not from a 2003 or maybe Suzuki had some leftovers from 2002 which ended up in 03's. I guess you can't beat finding one local and give it a magnet test. The different mounting system does seem better though.
Offline trackermatt91
« Reply #8 on: November 18, 2010, 07:10:23 PM »
i know this thread is old, but if you get a steel housing from a gv-or xl-7, with the mount, it bolts in and the stock kick cv's fit in or do you have to use the gv or xl cv's?
matt
« Reply #9 on: November 22, 2010, 11:20:50 PM »
You can just use the steel housing, but then you don't get to take advantage of the larger axles.
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #10 on: December 30, 2010, 07:25:26 AM »
I'm in the boat of "I destroyed the aluminum third member" (at least it was at a toys for tots event) and need to start calling junkyards. So my question is what do I ask for when I call? a 2004 or newer xl7, any year gv or xl7 with manual trans?
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
Offline Toys-n-Joys
  • 91
« Reply #11 on: July 03, 2019, 12:34:45 PM »
So a 2007 xl7 front diff and 3rd member will bolt directly into a 1995 sidekick? All I need to grab is the 3rd member mount, axles, diff housing and 3rd member?
I want a front locker and 32s so I need a steel housing swap. Any help would be appreciated
« Reply #12 on: July 03, 2019, 03:50:32 PM »
No - you need the axle housing and third member from an 03 or earlier XL-7 and swap your diff center over to the new third - if not you'll have to fiddle with the CV axles to get it to work.
Offline Toys-n-Joys
  • 91
« Reply #13 on: July 05, 2019, 11:32:40 PM »
Auto GV = Aluminum
Manual GV = Steel
Manual XL7 = Steel
I thought that the steel was the upgrade tho. I need a steel front diff swap
« Reply #14 on: July 06, 2019, 05:56:43 AM »
If you haven't already discovered it, you soon will, internet forums are sometimes filled with misinformation - I'll present what I have, you can accept it or treat it with scepticism as you choose.
The XL-7 was introduced in 2001 as a "stretched" Grand Vitara, and from the front it was indistinguishable from it's smaller engined sibling - apart from engine size, the differences were mostly aft the firewall.  From 2001 to 2003, the XL-7 used a front axle of similar style to that used on all the Sidekick, Vitara, Grand Vitara & Tracker models that preceded it.  From 2004 to 2006, the XL-7 used a completely different front axle design, and from 2007 to the end of production, the XL7 was a completely different GM based product, that did not sell well.
The 04~06 axle looks like this...
This does not have the traditional cast housing with axle tubes, into which the diff is assembled (salisbury style) or the third member fitted (banjo style) - the diff housing is split vertically and bolted together "sandwiching" the diff in between the two, and the axle tubes are then bolted on.
I'm not going to tell you it can't be fitted to your 95, I will tell you it's not the unit that people use for the steel front end swap.
The axle you have now looks like this ...
The axle you're looking for looks like this ...
Notice the difference in the third member mount - this was used from 02 onwards, make sure you get the matching fittings to bolt it to the cross member and it should bolt in.
You may be able to resolve your doubts by calling LowRangeOffRoad - they list the steel housing on their webpage - it'll cost you a grand, but it'll stop you from buying junk that won't fit.
