Help with 93
  • 1183 Views
Offline ridgerat4x4
  • 30
Help with 93
« on: December 29, 2010, 12:08:56 PM »
I just bought a 93 tracker and the older woman I bought it from has lost the keys I got it started buy taking the electric part of the switch off is there any way to remove the the key switch with out the key I am not a car theif we have a junkyard dad hauled this in with a clean title and a hard top looks to good to scrap lol
my crazy junk ,77 M35a2 duece and half,86 dodge long bed on 2.5 tons (under construction), 98 tracker, 91 dodge diesel
Offline beagle..t
  • 1239
  • 16
Re: Help with 93
« Reply #1 on: December 29, 2010, 12:54:55 PM »
if  u pull a door lock and get new keys cut from that  it should also work for the ignition too
Re: Help with 93
« Reply #2 on: December 29, 2010, 03:34:21 PM »
You can tear apart the steering column and remove the assembly, but you will need to get new keys all around.  You might check with your local Suzuki dealership, if you have the title they should be able to burn you new keys using the VIN.
