Towing a caravan with a sidekick sport.
  • 8 Replies
  • 3142 Views
« on: January 30, 2011, 07:32:16 PM »
What is the braked towing capacity of a sidekick sport?
A quick google search shows it is 1500lbs which seems low to me.
http://www.zuks-un-ltd-uk.freeservers.com/photo2_1.html indicates it has a towing capacity of 1500kg which is 3305lbs.
I also read a vehicle should not tow more than 85% of its weight.
I want to tow a small caravan.
Re: Towing a caravan with a sidekick sport.
« Reply #1 on: January 30, 2011, 08:36:50 PM »
I was thinking the sport was a little higher than the regular 4 door trackicks (which is 1500lbs).  But I am sure the sports capacity isn't over 2000 lbs.  I wouldn't tow any vehicle with a trackick.  But if you decide to, and you get in an accident, don't expect the insurance company to pay for anything, since you exceeded the towing capacity for your vehicle.
« Reply #2 on: January 30, 2011, 09:17:05 PM »
Is there any suzuki documentation from the sidekick sport brochure stating the towing capacity?
« Reply #3 on: January 30, 2011, 09:20:42 PM »
IDK, I don't have a sport brochure.  Looking for the spec online is probably your best bet.  Like I said, I am sure it isn't over 2K, it might even be the same as a regular 4 door at 1500.
« Reply #4 on: January 31, 2011, 10:26:13 AM »
Yep, same as the 4 door.  1500 lb.
0-60 in 12.5 seconds as well, apparently.  Oooo, 120hp!  That's not bad for an extra .2 liters.  :D
« Reply #5 on: January 31, 2011, 10:30:31 AM »
Yeah, it is an extra .2 liters, but it is also a DOHC engine, so that is probably the majority of the extra 25 HP over a 1.6 16V SOHC engine.
« Reply #6 on: February 01, 2011, 06:37:06 PM »
Vehicles in the US are very underrated for towing.  I'm from the uk and most tow vehicles are sedans.
What about a M101A2 3/4 ton trailer, 1500lbs.
« Reply #7 on: February 02, 2011, 02:29:23 PM »
That is because so many of us have half-ton pickups sitting in the garage as daily drivers.  I use a 1-ton to pull my SJ around.  :D
That trailer might be pushing it without trailer brakes.  They are listed at weighing 1300 pounds dry.  Throw 1000 pounds of weight on it and your looking at a trailer that weighs as much, if not more, then your Sidekick.  With a good hitch and trailer brakes maybe?
« Reply #8 on: February 11, 2011, 08:52:38 AM »
That's because the average american needs to be protected from themselves, and the vehicle manufacturers also need to protect themselves from the average american (and his/her lawyer).
Try getting your hands on the owners' manuals for two "equivalent" vehicles - let's say a US market 2.0 litre Vitara from 2001 and the same model of UK market Vitara - I'll take a bet the US manual has at least twice the number of warning notices as the UK manual.
