Needin info on solid axel conversion On tracker
  • 12 Replies
  • 2986 Views
« on: December 28, 2010, 06:53:34 PM »
I need info and pics of u have done I have a 93 model tracker thanks for the help
Offline beagle..t
  • 1239
  • 16
Re: Needin info on solid axel conversion On tracker
« Reply #1 on: December 29, 2010, 09:43:40 AM »
check out the diy builds they have alot of good pics and info there
« Reply #2 on: December 29, 2010, 03:25:04 PM »
What type of axle are you thinking of putting under the front end?
« Reply #3 on: December 29, 2010, 07:37:09 PM »
Not really sure either yota or just a Sammy any suggestions
« Reply #4 on: December 30, 2010, 12:59:20 PM »
Sammy will go on without to much of a problem, you just need to put on some wheel spacers so they are the same width.  If you go Toyota then I would swap both axles.  It really depends on what your planning on using it for.
How big of tires do you want to run?
Offline utahskibum
  • 76
« Reply #5 on: December 30, 2010, 06:45:01 PM »
Low Range has all the parts for a complete swap- I'm doing t- case gears at the same time but mine is almost done. Should have some pics soon and I will be at Zukfari too.
Offline DaddyDave
  • 204
  • Indeed
« Reply #6 on: January 05, 2011, 05:03:32 PM »
Go to the General Forum. CALMINI just released their SAS kit for the 1st gens.
"The maximum effective range of an excuse is 0.0 meters."
Offline trackermatt91
« Reply #7 on: January 27, 2011, 11:20:28 PM »
going links or leafs?  leafs and samurai axle would be easiest, make some hangars for the front spacers to keep the width same front and rear
matt
« Reply #8 on: January 29, 2011, 02:47:22 PM »
Thanks everyone I got her done today going to take her for a spin tonight
« Reply #9 on: January 29, 2011, 10:27:20 PM »
Pic's or it didn't happen!  :)
« Reply #10 on: January 30, 2011, 02:40:22 PM »
Haha I hear ya I'll try to get some up on here it did good though got to put some shock on it will beat you to death haha
« Reply #11 on: January 31, 2011, 05:52:03 AM »
he man just post on here people with trackers doing the straight axle swap what axles did you choose an have u put them in yet lmk thanks
« Reply #12 on: January 31, 2011, 03:06:54 PM »
Ya man put the samurai axle it was the easiest one to do and the cheapest I'll try to have some pics up soon
