mix and mash trans
  • 1439 Views
Offline bbyers01
  • 30
mix and mash trans
« on: April 12, 2012, 07:59:05 PM »
Can you mix and match the internals for a 5 spd that was in 2wd w/ 4x4 ?
I know the back section will have to swap over and am guessing the main shaft is different but didn't know about the counters and shift forks.
Trying to see if I can use parts from a 90-91(vin N for year) 2wd with my 96 (vin T) 4wd
Plan on getting new brgs and prob syncros.
Re: mix and mash trans
« Reply #1 on: April 13, 2012, 08:58:38 AM »
I don't have part numbers, to compare the two, but I believe the output shaft is the main (maybe only) difference on the tranny internals, between a 2wd and 4wd.
BTW, VIN "N"=1992,
Offline bbyers01
  • 30
« Reply #2 on: April 13, 2012, 11:36:06 AM »
Thanks for the year update.  Couldn't remember which letters wern't used.  I am going t o check w/ a trans part supplier in the next week or so when I order parts and will let everyone know if they say anything different.
