Headers
  • 3831 Views
Offline Jibs
  • 9
Headers
« on: November 20, 2012, 05:16:03 PM »
I recently bought the Calmini headers for my sidekick and found that the instructions say they're for a 1.6L, and my sidekick is a 98, which has the 1.8. The description where I bought it from was unclear in this and when I tried to take my exhaust stuff in to get installed, they said they couldn't put the header on. Are the 1.6 and 1.8 different?
Offline jwarnick11
  • 46
  • Jeep? you know barbie drives one of those.
Re: Headers
« Reply #1 on: November 20, 2012, 05:37:38 PM »
Yes they are slightly different. But the reason Iv gathered for there not being headers for the 1.8 is because the stock manifold is pretty much the same thing as a header.
94 kick 1.6 16v
fully rebuilt motor with custom head work
doug thorley header
jeffs 2in spacer lift
30x9.50 on 15x8 cragers.
Offline Jibs
  • 9
Re: Headers
« Reply #2 on: November 20, 2012, 05:43:17 PM »
Ok perfect. Looks like I'll be returning this thing then. Thanks a lot.
Re: Headers
« Reply #3 on: November 21, 2012, 03:00:36 PM »
Isn't there a company out of Australia that makes headers for the 1.8l and 2.0l motors?
Re: Headers
« Reply #4 on: August 19, 2015, 06:05:07 PM »
There is a header made in Australia for the J20, that will fit the J18.  There are a few things to consider before buying it.  You have to add your own EGR tube and the hanger bracket from the catalytic converter needs to be removed.  I would also suggest that a section of flex-pipe is added between the header outlet and the catalytic converter.
Here are pictures from my J18 install.
Edit:  Well I just replied to an ancient post.  No activity here since the reboot?
« Last Edit: August 19, 2015, 06:07:27 PM by Ridjobradi »
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Headers
« Reply #5 on: August 19, 2015, 06:46:23 PM »
So the stock exhaust manifold on the 1.8 engine was made out of cast metal?   The J20 is made of  tubing.
Re: Headers
« Reply #6 on: August 19, 2015, 10:10:36 PM »
The Sports had a cast manifold that cracked easily.  If you zoom in, you can see cracks at nearly every place a runner meets another runner and some are perpendicular to the runner.
