Temperature sensor question
  • 1948 Views
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« on: September 27, 2010, 06:07:21 PM »
I replaced my temperature sensor because the spade connector broke off and the gauge wasn't working.  Now, the gauge goes to the halfway point before it even warms up and then moves up slightly after it is warm.  I replaced it with Duralast part number TU89 from autozone, which is what their system says is the part number.
What is wrong?
Did I get the wrong sending unit?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
Re: Temperature sensor question
« Reply #1 on: September 28, 2010, 08:40:22 PM »
I wouldcheck all the wiring, make sure it correct, I think there is only two wires. Mine goes up to normal range and when I hit the gas it goes back down,I have to wiggle the spades every now and then to get itto work.how much was the auto zone unit?I wouldcheck out suzuki,
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
  • 169
  • Black Sunshine
« Reply #2 on: September 29, 2010, 03:34:17 AM »
The temperature switch on mine only has one wire and is at the front of the thermostat housing.  The part was $13.99 at Autozone.
Black Sunshine
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #3 on: September 29, 2010, 01:54:39 PM »
I will check mine tonight, and update
#801-554-3281
« Reply #4 on: September 29, 2010, 05:27:20 PM »
You can test the sender with an ohm meter. It should slowly change as the vehicle warms up.
Check your water level.  I had a similar issue when I had a leaking heater hose.  I would get an air bubble in the cooling system and the temp sensor would show the wrong reading for a while the suddenly kick in.
Offline tipover
  • 422
« Reply #5 on: November 09, 2010, 04:30:13 PM »
did you get it tight?  did you use goop or teflon tape?  The sender works as a variable resister to ground.  if it has bad ground, it will be innaccurate.  i would check that first.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline dennisl
  • 23
« Reply #6 on: December 17, 2010, 03:23:59 PM »
My 97 tracker had the spade loose on the temp sensor. I soldered it on and it has worked great since.
