Blinking 4WD light?
  • 3298 Views
Blinking 4WD light?
« on: January 06, 2011, 11:02:51 AM »
I had my XL7 in 4wd for an extended period of time (6hours) last weekend while traversing some ice packed roads.  I noticed after a while that the 4wd indicator light on the dash would blink off briefly every once in a while.  The vehicle stayed in 4wd.  has anyone else experienced this?
Re: Blinking 4WD light?
« Reply #1 on: January 06, 2011, 07:29:45 PM »
I believe it's fairly common - at least it is on the '98~'05 GVs that the XL7 is based on.
The front differential has an air operated free wheel clutch - which acts as a replacement from manual or automatic free wheel hubs.  When you're in 2WD the clutch is disengaged and the front wheels are not connected to the differential, when you select 4WD, the ECU turns on a little air pump behind the front bumper and that pressurizes the system and the clutch engages, connecting the front wheels to the differential, so that you have 4WD - the pump turns off and the 4WD light turns on.
If the pressure drops below a certain level the pump will turn back on briefly to maintain pressure so that the clutch will stay engaged and the front wheels stay connected to the differential - it is when the pump turns on, that the 4WD light winks off, and when the pump turns back off, the light comes back on.
I'd say if it's just the occasional blink, it can be ignored, but if you notice it blinking more & more frequently, it's an indication that the system has an air leak - maybe a cracked or loose hose, sometimes the pump fails, sometimes it's the actuator in the differential itself.
EDIT - This may or may not be applicable to your particular XL-7 - depending on the year.  I just had a look at the parts catalogs - up to '03, the XL-7 used the same ADD setup as the GVs, but '04 and later are different - there is still an ADD, but I have no idea how it works.
« Last Edit: January 07, 2011, 04:34:23 AM by fordem »
Offline trackinstile
  • 435
  • Too young to quit........Too old to change........
« Reply #2 on: January 07, 2011, 02:13:17 AM »
Is that what that is????  I just figured it was a fluke thing with mine, it only blinks every once in a while, and it's always in 4WD, thanks for shedding light on that.  Dave
A wise man once said, "Wherever you go...........There you are.............." 2000 Tracker 4 door with the 2.0 liter "Big Block". 5 speed 4WD  2001 XL-7 EX II
« Reply #3 on: January 07, 2011, 07:24:12 AM »
Thanks.  I'll keep an eye on it.  It blinks every couple of minutes right now.  i had necer noticed this before so I may have a leak starting.
