Would a Calmini lift help with alignment issues?
  • 2112 Views
Offline cworkm
  • I
« on: April 20, 2005, 09:02:33 AM »
I didnt get any responce from the GV side,
Would a Calmini lift help with alignment issues? It seems like every
other time I go off road my alignment goes out..
Offline blacknight
  • 987
    • Gonzookin
Re: Would a Calmini lift help with alignment issue
« Reply #1 on: April 20, 2005, 12:49:07 PM »
What are you doing to do this???  jumping, rocks .....
It might but than again it might not.  :-/
Geogre
Offline nomaad
  • 179
  • I wanna go!!
« Reply #2 on: April 21, 2005, 02:02:21 AM »
Are you using EZCam bolts for alignment?
If so, my passenger side goes out after tough terrain as well. I think I need to replace them as I have had them on and off about 100 times doing mods and fits. May have stripped the ecentric a little or something. It definately rolls around after hard wheeling though.
Offline cworkm
  • I
« Reply #3 on: April 21, 2005, 04:00:16 AM »
No, Im not using the EZcam bolts at least not that I know of, i take mine to Big O tire.. But its my passanger side too, its always going out..  >:(
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: April 21, 2005, 05:46:46 AM »
Whats going out camber? toe?
George
Offline nomaad
  • 179
  • I wanna go!!
« Reply #5 on: April 21, 2005, 06:55:04 AM »
Mine is Camber, but if he is not using a cam bolt his has to be toe or caster, which would be a tie-rod thing. Could also be he thinks it is out of line if the steering wheel is cocked. Which could be a slippy steering shaft coupling or stripping some teeth off the Pinion stub. . . ???
Offline cworkm
  • I
« Reply #6 on: April 21, 2005, 07:35:25 AM »
Mine is wearing to the inside of the tire. Im not sure if that is toe or not. I had Yokohama Geolander ATs put on about 3 months ago and at that time i had the alliment fixed. Ive been off roading 3 maybe 4 times since. I just went in to get the tires rotated and the pasanger side tire looked like it was a year old from wear.. the rest were kinda warn but not to bad.
