Sidekick won't idle
  • 7 Replies
  • 1948 Views
Offline LBC4x4
  • 78
  • 1992 4door 3" body 1"coil spacers 31x10.5
Sidekick won't idle
« on: February 20, 2011, 07:12:14 AM »
I have a 92 Suzuki sidekick with a 1.6 l 16 valve motor. I can't get the motor to idle. It will fire and run as long as I hold the ignition but as soon as I let off  the ignition it drops rpm and stalls. I checked the fuel pump and it has good pressure and don't know what to check next. I opened the distributor cap and there was some slight corrosion on the contacts. Could this be the problem?  Any help would be great thanks.
Re: Sidekick won't idle
« Reply #1 on: February 20, 2011, 08:47:54 AM »
Hold the ignition? like in the start position or close to it?
You might just have a bad ignition switch
Offline LBC4x4
  • 78
« Reply #2 on: February 20, 2011, 08:59:18 AM »
When I turn the ignition to Start the car it will start and if I hold it in the turned position the engin will run. Then when I let it rotate back to the "running" position it stalls. Where is the ignition switch and is there a way to test it?
« Reply #3 on: February 20, 2011, 09:31:24 AM »
The switch is right behind the key cylinder, you might want to take it to
someone to work on it, unless you think you can get it, but it sounds like
the contact in the switch is bad, I think a heavy set of keys contributes to
this problem, I had to replace mine a number of years ago too
« Reply #4 on: February 21, 2011, 04:42:29 PM »
Check your tail-dome fuse.  It provides memory power to the ecm, and controls the ground to hold the Main power relay in (I think).  I had this problem when I first tried starting my new engine.  It would start and run in the start position only.  I found a bad fuse, replaced it and ran fine.  If not your Tail-Dome fuse check the others.
  • 6597
  • 68
« Reply #5 on: February 22, 2011, 04:16:04 PM »
X2
Offline LBC4x4
  • 78
« Reply #6 on: February 28, 2011, 02:53:35 AM »
Alright guys, I checked all the fuses and now I cant get it to start fire. I am getting spark on all the cylinders but can't get it to fire. When I try to start it j can smell fuel but still no ignition. I have even tried starter fluid in the intake.  What can I try next
« Reply #7 on: February 28, 2011, 08:39:00 AM »
If you have spark and fuel it will start, when does it have spark? when do you
smell gas? Still sounds like a bad ignition switch, I had an old VW that did this,
would not start while cranking, only when you let off the start position then
the engine would start, it was a defective switch.
You need a helper to check the spark while cranking
