1.3l intake manifold gasket
  • 10 Replies
  • 7598 Views
Offline 02CalTaco
  • 196
« on: January 02, 2012, 10:55:20 PM »
Ill be replacing the stock intake manifold with another stock manifold on my 86 samurai. I found 2 choices from autozone http://www.autozone.com/autozone/parts/1986-Suzuki-Samurai/Intake-Manifold-Gasket/_/N-iuqstZaliz2 , a felpro gasket that looks like a standard flat paper type gasket and a victor reinz one that from the picture looks to be maybe a rubber? raised profile gasket. Orielly's has the same gasket style choices but beck arnley instead of the victor reinz.
I was just going to go with the felpro standard gasket with some gasket dressing but after seeing(pictures) the other ones Im wondering if they are a improved or better option over the standard paper type gasket, I assume they would not need any additional sealant or dressing.
Does anyone have an opinions, recommendations or experience with these gasket choices ?
Offline Capt
  • 738
  • 28
Re: 1.3l intake manifold gasket
« Reply #1 on: January 03, 2012, 05:32:07 AM »
My only advice is CLEAN..... CLEAN..... I mean CLEAN off both the head & intake surfaces.
Permatex makes a spray on "Copper Plate" gasket sealer that I have used with great results.
Also it would not hurt to "Gasket Match" your intake & head ports since you have everything apart.
Just be careful if you haven't worked on aluminum as it grinds easily with a good rasp bit.
and don't make it baby but smooth, a little turbulence keeps the gas suspended in the air flow
and helps vaporize it.
Smooth runners are for High RPM racing apps.
Helping that little 1.3 L breath gives it a little more power.
CAPT
« Reply #2 on: January 04, 2012, 05:25:01 PM »
The victor one is actually metal.  It is a better gasket than the felpro paper one, IMO.
Offline 02CalTaco
  • 196
« Reply #3 on: January 04, 2012, 06:49:20 PM »
Thanks for the info. Is it metal with raised rubber around the ports ? Is that kind of gasket installed with out additional sealant or dressing ?
The Victor one is only $1-2 more than the felpro but the Beck one from orielly's, that in the picture looks just like the victor one is $10 more than the felpro.
« Reply #4 on: January 04, 2012, 06:57:49 PM »
No, it is all metal.  At least it is on the ones I have seen.
They just get installed dry.
The metal gasket is the type that the 1.6 8V uses from the factory.
Offline 02CalTaco
  • 196
« Reply #5 on: January 05, 2012, 09:20:15 PM »
Ill order the Victor so I can see at least see it, I can always return it. Asking the people that work at these places gets me nowwhere, they all say to use additional sealant.
« Reply #6 on: January 05, 2012, 09:23:43 PM »
That metal gasket is the same type as is used on the 1.6s from the factory...and they don't use any type of additional sealant.
Offline 02CalTaco
  • 196
« Reply #7 on: January 10, 2012, 08:52:30 PM »
Got the Victor gasket today, it is metal. It's raised around the ports on the head side and recessed on intake side. Not sure how that works but I guess I'll just have to trust that it seals. Any special torque sequence?
« Last Edit: January 11, 2012, 10:02:42 AM by 02CalTaco »
Offline 02CalTaco
  • 196
« Reply #8 on: January 12, 2012, 08:10:39 PM »
Anyone, torque sequence?
« Reply #9 on: January 12, 2012, 08:19:30 PM »
As long as the manifold surface and the head surface is flat, it will seal fine.
I'd start in the middle and work towards the ends in a criss-cross pattern and in a couple or three steps....kinda like how you do the head bolt sequence.
Offline 02CalTaco
  • 196
« Reply #10 on: January 13, 2012, 06:51:29 PM »
Thanks !
