1.3L Samurai runs EXTREMELY rich
  • 5642 Views
« on: December 12, 2011, 05:25:12 PM »
Hey guys, I am a newb mechanic and I have a problem. My 91 EFI samurai is running very rich. You can smell the gas as it idles and it will actually leave a patch of gas on the ground under the exhaust pipe in the morning. I've also noticed that my gas mileage has gotten worse by about a quarter! Things I have replaced recently are: PCV Valve, Throttle body gasket, Valve cover gasket, plugs, wires, distributer cap and also what I think was an air temp sensor on the intake manifold.
Any help would be GREATLY appreciated.
Re: 1.3L Samurai runs EXTREMELY rich
« Reply #1 on: December 12, 2011, 06:15:34 PM »
Fuel pressure regulator might be bad.  ECM could be going bad and causing it to run rich.  O2 sensor might be bad.
« Reply #2 on: December 13, 2011, 02:44:24 PM »
Did you gap the plugs before you put them in? Why did you change the sensor and are you sure that the replacement was the correct one?
« Reply #3 on: December 13, 2011, 05:09:09 PM »
Thanks guys for the replies.
I didn't gap the plugs, reason being that I didnt have the tool and I also thought that the factory gap on the new plugs was close enough (.035"). I figured a couple thou wouldn't make much difference especially because the ones that came out were WAAAAYYY worse (like .050-.060). Was this a stupid idea?
 The sensor I replaced was the Air Charge Temperature Sensor. I replaced it because I thought it might help with some power issues I was having and also the old one had a crack in the sensor.
I was investigating my o2 sensor but I didnt know how to really diagnose it. In the Haynes manual it says to rev your engine to 2000 rpms and the output voltage of the sensor should be .45 V (I think that what said). My problem is that I dont have a tach. and I was just guessing at the rpms. Is there a general rule of thumb with o2's, for example will the voltage increase or decrease with higher rpm?
Offline ebattleon
« Reply #4 on: December 14, 2011, 12:45:32 PM »
Get a copy of the Suzuki's FSM it has everything you need...and the Haynes is a load of crap:(
Common Sense Absent
Offline 1969dane
  • 19
« Reply #5 on: December 19, 2011, 03:10:06 PM »
 What about your idle air sensor?
Leaf springs rule!!
« Reply #6 on: December 20, 2011, 04:56:41 PM »
Im not quite sure what you mean. Where is it located and how would it affect the fuel air mixture?
