16v bogging down
  • 30 Replies
  • 6357 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
16v bogging down
« on: June 08, 2010, 07:33:44 AM »
It all started after i changed the o2 senser not sometimes then i drive i will shift and get back in gas it seams to bog down i push harder and its like it clears up could my TPS be acting up?
Re: 16v bogging down
« Reply #1 on: June 08, 2010, 07:46:49 AM »
TPS, dirty MAF, low fuel pressure/plugged filter, plugged CAT, dirty air filter
and perhaps a slipped timing belt could all be contributing to this problem.
Start with the easy stuff, like the air filter and work through it
Offline KJMac
  • 280
« Reply #2 on: June 19, 2010, 08:12:12 AM »
Don't maen to hi-jack but mine is doing the same thing it is missing too. It gets worse when I advance the timing and when I'm at light throttle cruise it is most noticeable
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
« Reply #3 on: June 19, 2010, 03:09:26 PM »
that sounds like plugs or wires or both, also check
the gap on the plugs
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #4 on: June 19, 2010, 06:06:45 PM »
new timing belt   no cat  run fine till i changed the o2 senser
Offline KJMac
  • 280
« Reply #5 on: June 23, 2010, 09:24:37 PM »
My 02 censor isn't very old! I checked the tps,coil,igniter,iat,plug wires and plugs have 2k miles on them and the fuel pump has about 4k miles. I went out to start it one day and it was running cruddy. I went 30mi. One way and the further I went the worse it seemed to run. Same thing coming home!
« Reply #6 on: June 23, 2010, 11:23:07 PM »
Well for peat sake, put the old one back in !!
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #7 on: June 24, 2010, 06:25:14 AM »
replaced do to a wire broke off.    it runs great when I first start it and drive.    if I stop some where and turn it off when i start it again is when it happens it bogs under load on the bottom half of the pedal.  it will go away in 15-20 minutes if driving. I wonder if its loading up that's what it feels like
« Reply #8 on: June 24, 2010, 07:34:50 AM »
You might of got a bad one, I got a bad Bosch O2 sensor once,
and I really didn't think that would happen.
Your O2 is a 3 wire one and heated, a non heated one will work also, you
just need to connect the right wire, you might check the replacement for
the correct readings, if I remember right, the pins are diagonal from each other
these are the heater pins, the sensor to computer feed is the one by it's self
in the corner, with an ohm meter check the heater pins for continuity, if they
don't give you a value or are open circuit replace the O2.
Also check for voltage at the plug on the truck, if this is dead, the heater won't
heat the sensor and it would act like what you described
« Last Edit: June 24, 2010, 07:36:28 AM by wildgoody »
Offline KJMac
  • 280
« Reply #9 on: June 24, 2010, 10:32:58 PM »
I changed plugs,wires, O2,changed out the tps with one I had. The coil is reading 1.0 primary and 12.99 secondary. According to my haines manual it is way out of spec! My book says it should be 22-30k ohms. How are you guys with the 16 valves checking you fuel pressure with the banjo fitting and no valve stem on the rail. Are guys putting fuel pressure gauges at the end of the fuel rail? Thanks guys!!! I'm thinking it is the coil or TRE fuel pump. It is a little intermittant but misses every where.
Offline KJMac
  • 280
« Reply #10 on: June 24, 2010, 10:40:18 PM »
I wanted to add something I thought was odd. When I tested the coil secondary resistance it was coil positive to the coil post that goes to the dist. Cap. I then tested the negative to the dist. Cap tower and it also read the same...12.99ohms. Thanks,
KJ
Offline KJMac
  • 280
« Reply #11 on: June 25, 2010, 08:16:39 PM »
I went and checked fuel pressure and it is in spec! I think I have a computer problem. It is cutting out when i hold it at part throttle in the driveway so I hooked up a volt meter to the injectors. when it cuts out it is just like someone turned the key off and back on while holding the throttle steady. any help would appreciated.
Kevin
« Reply #12 on: June 25, 2010, 09:06:35 PM »
check your grounds, the injectors get grounded to fire, if the ECU has
a bad ground it could do that
Offline KJMac
  • 280
« Reply #13 on: June 25, 2010, 09:23:14 PM »
Thank you, will check it out.
kevin
« Reply #14 on: June 25, 2010, 09:34:25 PM »
There is a bundle of ground wires on the 8V engine on a bolt
or nut where the distributor is, I think it will still be there on the
16V engine, start there, and make sure they are all connected
and are clean and no corrosion on the connectors
