Dash vent removal
  • 9 Replies
  • 7059 Views
Offline 02CalTaco
  • 196
Dash vent removal
« on: December 04, 2011, 11:53:40 PM »
A previous owner painted some of the interior trim pieces, gauge bezel and dash vents, its really not my style. Ive been looking for some dash vents with bezels and gauge surround to replace these but haven't had any luck yet. I was thinking about just re painting this stuff dark gray but I'm not sure how to safely remove the dash vents. The ducts were never reattached from when these were painted so I would also like to do that, unsure how also.
Re: Dash vent removal
« Reply #1 on: December 05, 2011, 05:35:04 AM »
What vehicle are you working on?  What year?
Offline 02CalTaco
  • 196
« Reply #2 on: December 05, 2011, 01:11:42 PM »
86 Samurai.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #3 on: December 05, 2011, 01:30:20 PM »
I'll send you some info and hook you up......  ;)
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #4 on: December 05, 2011, 02:23:01 PM »
You Got Mail.....  :laugh:
Offline Capt
  • 738
  • 28
« Reply #5 on: December 05, 2011, 04:02:32 PM »
I replaced my "Round Style Vents" with 2" Gauges.
They fit right in the vent openings. You will have to remove the entire dash
 to do a good job and get all the wires neatly tucked in.
CAPT
Offline 02CalTaco
  • 196
« Reply #6 on: December 06, 2011, 07:56:11 AM »
CAPT
So the dash needs to be removed completely or is there a way it can be moved enough to get behind it? I just want to remove and replace the round vents and hook the ducts back up. Whats the easiest way to do that? Removing the whole dash sounds like a beating.
« Reply #7 on: December 06, 2011, 08:45:28 AM »
The dash vents just pop in and out of the dash.  But they can be hard to remove sometimes (they have little tabs that hold the vents in the dash).  The easiest way (although, it also takes the most time) is to remove the dash, or at least take it loose, so you can move it enough to reach in behind the dash and push the ducts onto the back of the vents.
Offline Capt
  • 738
  • 28
« Reply #8 on: December 06, 2011, 02:49:46 PM »
It's not as bad as you are thinking to remove the entire dash.
The hardest part is getting the Speed0/Tack benzel past the 4-way knob.
You will have to remove it first, then the speedo/gauge cluster,...
then its just all fillips screws to get the rest of the dash off.
You should have it out in about.....1 six pack.
Just take your time & you can also now easily clean the top of your heater core (See a previous post of how)
Then you can do all the work without needing skin grafts for your hands & Knuckles!!
CAPT
« Reply #9 on: December 07, 2011, 08:26:46 AM »
Removing the gauge cluster isn't a big deal.  Just take the 2 bolts out of the steering column that hold it to the crossbar under the dash and the steering column will drop down and make it pretty easy to remove the cluster.
