my original 1.3 sammie motor just
  • 2888 Views
Offline dirtzero
  • 55
« on: March 08, 2010, 03:06:02 PM »
What other suzuki 4 cylinders will fit? Anyone know where fine a  used motor? ebay has noting. It is squirting oil out the blow out valve at the top of the motor.
Bobthebiker
Re: my original 1.3 sammie motor just
« Reply #1 on: March 08, 2010, 03:10:31 PM »
I think the 1.6 is a bolt in motor,  and with some work, you can make many others fit.
but if you're spraying oil out the top of the motor, you've got WAY too much oil, or something is causing it to do that.  check these things.
Offline dirtzero
  • 55
« Reply #2 on: March 08, 2010, 03:22:01 PM »
nah i dont have to much motor belive me. Idk what could be wrong with it maybe someone could help. Im not super familar with these types of motors? a 1.6 motor out of a what?
Offline zukimoo
  • 330
« Reply #3 on: March 08, 2010, 03:56:07 PM »
you can bolt in:
1.3 from a suzuki swift DOHC (good horse power) just needs a few mods but will bolt in
1.3 from chev fire fly
1.6 from tracker, sidekick, sunrunner will fit but needs a kit to bolt to tranny, some extra work.
I bought a 1.3 DOHC motor from Japan Auto. They bring in motors from Japan because over there they can only run motors to 50K and then the car is scrapped. Any import motor will be there. The motor costs less than me rebuilding mine. I needed to source out some other parts.
06 Baja Buggy
Offline dirtzero
  • 55
« Reply #4 on: March 08, 2010, 04:07:17 PM »
does japan auto have a website? are you taking about the newer 1.6 swift motors? its seems imposible to find a sammy engine sitting the junkyard.
Offline dirtzero
  • 55
« Reply #5 on: March 08, 2010, 04:09:41 PM »
what could be causing the oil to squirt of the top? rings? I mean it still runs but smokes like crazy and a motor loose of power.
