1988 Suzkuki Samurai in deep water!
  • 7 Replies
  • 2901 Views
« on: May 31, 2012, 04:05:45 PM »
Yesterday i got my 1988 suzuki samurai stuck in pretty deep water. It had to sit in it for about a hour the carb was out of water put my plugs coil starter altornator and all that was under. I roll started it drove it back back home once i got pulled out today the key wont start it still. I drained oil out witch might as well of been water, what all other things should i check? and or replace  Thanks for any help.
Offline BLOODBANE
  • 144
Re: 1988 Suzkuki Samurai in deep water!
« Reply #1 on: May 31, 2012, 06:55:52 PM »
Unfortunately the first thing you should have done was pull all the plugs and turn it over. If you had water in the cylinders it would have hydro-locked the engine. This will cause all kinds of internal problems. It ran which is a good sign, but still might be in need of some serious overhaul. If your electrical connections got soaked it could be as simple as pulling the connectors apart and using some die electric grease in them. If you ever find yourself in this spot again follow these steps first, 1. pull all the plugs (remember firing order), 2. crank the engine (water will come out the plug holes), 3. replace plugs (after your sure all the water is out) and re-start your engine. This was the main reason I put a snorkel on my Explorer (poor fresh air intake placement). It doesn't get any water in it now....
84 Ranger/6" lift/347 stroker/C-6/35"Boggers/lockers F&R-94 Explorer/7"lift/35'BFGs/lockers F&R/87 Samurai 6"SPOA,6.5:1 T-case, soon 1.6 16v,32" Pro-Comp MT's.
Offline SineCredulitas
  • 73
« Reply #2 on: May 31, 2012, 09:03:56 PM »
You might change the diff's, trans, transfer case gear oils too. Might have got some in and might as well cover your bases.
Trans/transfer needs yellow metal friendly type gear oil I believe.
88.5 TT, dd, 1.6 16v, 5sp, a/c, SPUA, 30" MTR's
Offline warbird
  • 110
« Reply #3 on: June 01, 2012, 07:02:35 AM »
Did the computer stay dry?
« Reply #4 on: June 01, 2012, 07:29:20 AM »
I didnt hydrolock it. Starter sealonid is out for sure. Starts everytime just runs ruff think i got water in my gas im going to buy a bottle of heet today to try and fix that. Im going to change all my fluids, should i change all my plugs and wires? Thanks for the input.
« Reply #5 on: June 01, 2012, 07:31:25 AM »
Im not aware the 88 carbourated one had a computer but as far i know it must of all my gauages still work and all my lights work headlights and dash lights. There is a little red light by my rear defrost that is on that has never came on before this. Any idea what that is?
  • 73
« Reply #6 on: June 01, 2012, 08:47:04 AM »
My orange/red light below defrost button illuminates when defrost is powered/in use...
Offline Zuki-Girl
  • 128
« Reply #7 on: June 09, 2012, 05:45:47 AM »
 If still running the stock carb,yes it has comp for that, if changed to another don't worry.
