samurai horn relay
  • 4515 Views
samurai horn relay
« on: April 21, 2010, 05:11:59 PM »
 took out the horn and connect it directly to the battery it worked fine so now i went on to test the horn wires with the test probe had some body push the horn button but i did'T GET ANY POWER WAS THINKING IF IT COULD BE THE HORN RELAY BUT DON'T KNOW WHERE IT IS LOCATED CHECKED FUSE IT WAS GOOD ALSO.
Re: samurai horn relay
« Reply #1 on: April 21, 2010, 11:36:43 PM »
It is most likely a switch issue.  On the SJ there is 12v applied to the horn and it grounds out through the steering wheel.
« Reply #2 on: April 22, 2010, 08:10:15 PM »
Most of the Suzuki electrical system works like that, the switched
side is the ground, the wires are "hot" all the time
« Reply #3 on: April 23, 2010, 04:38:20 PM »
I disasembled the steering wheel yesterday  hooked up the horn and grounded out the wire on the steering wheel but nothing  should there be power on the steering wheel wire then i have an 1988.5 sammie and also should i discard  the idea of the horn relay been bad.
