4dr spring on 2dr
  • 1462 Views
Offline airdale navy
  • 82
4dr spring on 2dr
« on: March 26, 2012, 06:38:21 PM »
How much lift can you get by putting 4dr spring in a 2dr (sidekick)?And does it ride better than a suspension a lift.
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
Re: 4dr spring on 2dr
« Reply #1 on: March 26, 2012, 11:49:39 PM »
You get between 1 inch to 1 1/2 inches, depending on the condition of both springs.  Seems like it is more noticeable on front.  The ride is better than spacers.  If you want more lift, there is Ford ranger springs for front, and Honda springs for the rear.
  • 82
« Reply #2 on: March 27, 2012, 02:26:31 PM »
honda springs !Tell me more!
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #3 on: March 31, 2012, 05:54:31 AM »
Just a word of caution with doing this.. there is a point where the CV joints tend to pull / blow out at flex. I am thinking this is somewhere in the 3-3.5" + range.
I used 2" spacers with 4 door springs for about 3-3.5" of lift. Although I had no problems it was mainly due to not wheeling it. (I sold it before having a chance to wheel it.)
You will also need to adjust your camber accordingly once the install is complete.
