4wd ligth turns on when air pump unpluged 04 gv 2.5
  • 7 Replies
  • 2224 Views
Offline memex
  • 18
« on: November 14, 2016, 02:05:52 PM »
I'm having trouble with my 2004 grand virata 2.5 v6 4wd front diff not engaging and the 4wd light turn on when I disconnect my air pump actuator and I seem to get constant power to the red and pink power not sure where to go from there I had a clutch job done before it stopped working but the shop is really far I would like to fix it myself
Front diff not engaging
4wd light turns on when air pump disconnected
Air pump not turning on
Constant power to red and pink wire black wire is neutral
Clutch job done before 4wd not working
« Last Edit: November 14, 2016, 02:21:34 PM by memex »
Re: 4wd ligth turns on when air pump unpluged 04 gv 2.5
« Reply #1 on: November 20, 2016, 08:23:57 AM »
First place I would check is the 4WD switch on the transfer case - make sure it was reconnected after the clutch job.
Next - the pump should run if you have constant 12V power on the red wire, so let's take a look at that - remove the pump from the vehicle so you can bench test it - connect the black wire to the battery negative and the red wire to the battery positive, the pump should start & run, if it doesn't, it's defective, if it does, cap the outlet with your finger, the pump should stop, and restart when you remove your finger.
Offline memex
  • 18
« Reply #2 on: November 21, 2016, 02:47:10 PM »
Thank you for the reply I'm going to check the switch on the transfer case tomorrow I have 2 pumps and both of them work but only if I connect the pink and the black on negative and the red on positive I don't know if that is normal operation for the pumps from the troubleshooting I've done today its probably the switch on the transfer case I just have to find it :/
Offline memex
  • 18
« Reply #3 on: November 22, 2016, 12:12:43 PM »
how in the world do i access to tc switch? to i have to drop the tranny
Offline memex
  • 18
« Reply #4 on: November 22, 2016, 04:33:49 PM »
Update transfer switch is in the transfer case... I need a how to trouble shoot transfer switch...
« Reply #5 on: November 23, 2016, 06:30:03 AM »
Find the connector and check for continuity to chassis ground when 4H or 4L is selected.
Offline memex
  • 18
« Reply #6 on: November 23, 2016, 03:25:59 PM »
fixed it !!!!! mechanic bent my tc switch pin inside the connector
« Last Edit: November 23, 2016, 03:28:48 PM by memex »
Offline memex
  • 18
« Reply #7 on: November 23, 2016, 03:27:48 PM »
i will be posting more pictures this week on how to access transfer case switch for future noobs
