4x4 has trouble turning
  • 8 Replies
  • 3313 Views
Offline ben256
  • 16
« on: October 14, 2009, 03:55:42 PM »
1995 sidekick. when in 4wheel drive it has alot of trouble turning sharply, such as when i am parking. is this normal or is there someting wrong with my kick's 4x4?
  • 6593
Re: 4x4 has trouble turning
« Reply #1 on: October 14, 2009, 03:58:51 PM »
That is normal... When in four wheel drive and turning sharply on a surface with a good deal of traction, your vehicle will buck.
Offline ben256
  • 16
« Reply #2 on: October 14, 2009, 04:13:37 PM »
alright thanks man, i thought that it probably was, but i got thrown off by all those performance AWD cars turning no problem
thanks
« Reply #3 on: October 14, 2009, 05:36:22 PM »
Yeah, those have special powertrains to spilt the torque between the front and rear allowing the front to travel faster than the rear. Chevy had it on some of there old fulltime 4x4's, lift one wheel off the ground, and you would have no wheel drive, They have since fixed that problem.
Offline ben256
  • 16
« Reply #4 on: October 15, 2009, 08:21:33 AM »
ah thanks
Offline fuzzy1
  • 350
« Reply #5 on: October 15, 2009, 09:45:01 AM »
Just a note, if you don't know: DO NOT engage 4wd on dry pavement, or even just wet pavement. It will torque lock the 4wd system & cause damage. 4wd needs a loose surface, ie dirt, gravel, sand, grass, snow etc. to allow it to slip a little to make up for the difference the wheels travel around corners. Hth.
Fuzz
Non Illegitimi Conterat
Offline Minmatar
  • 262
  • That lake is just too clean....right zuki? >=)
« Reply #6 on: October 15, 2009, 10:32:21 AM »
Fuzz
Ok what do you do You're butt end is in a ditch while you're front set is on tarmac. What do you do?  im talking 55 deg angle here. do you risk the torque lock or pray to god your open end can spin long enough to push you out? >=)
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
« Reply #7 on: October 15, 2009, 11:24:17 AM »
Then your fine.  And it is fine for short distances, you just need one of the two ends to be able to slip a little.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #8 on: October 15, 2009, 01:26:57 PM »
Fuzz
Hi. The answer is put it in 4wd and drive out.
Then - unless you are in a driving snowstorm, in the middle of a desert or in a heavy downpour - you shift back to 2wd.
That's because Samurai/Sidekick/Tracker trucks are NOT all-wheel drive.  They are part-time 4wd.
Driving on flat, dry surfaces in a part-time 4wd vehicle is seriously not good for the drivetrain.
See Mr. Bewley's post, above.
n'est-ce pas?
Ack
