5sp getting in gear problems!!
  • 10 Replies
  • 2780 Views
Offline JNM78
  • 14
  • " I like mud"
« on: October 07, 2010, 01:38:23 PM »
  I have a 95 kick w/a 5speed, have new clutch/preasure plate, and cable.  The problem is that it wont go into 1st or 2nd, and grinds into rev. unless I put the transfer case into neutral, then it will go into all of the gears fine.
 So when i,m on the trails or muddin I put the xfrcase in -n- and then sel 1st or 2nd and then 4L and off i go. Can someone help me.
 I would like to rebuild the tranny.  can anyone let me know where to buy a kit, and are there any special tools needed?
Re: 5sp getting in gear problems!!
« Reply #1 on: October 07, 2010, 02:56:17 PM »
Sounds like your clutch is not disengaging completely.
Offline gearjam
  • 97
  • RC 2010
« Reply #2 on: October 07, 2010, 06:07:03 PM »
I agree with above
« Reply #3 on: October 08, 2010, 04:00:55 PM »
Check your clutch cable. The casings will break down over time and allow the cable to kink or bend causing this problem.
Offline JNM78
  • 14
  • " I like mud"
« Reply #4 on: October 10, 2010, 03:18:38 AM »
 I found the problem, Had mud packed in the bell housing. I had to put it up on jacks and use the hose and air gun to blow out the mud. working fine now.
 I did notice that the plastic cup under the shifter ball is missing, Does anyone know where i can find these parts?
« Reply #5 on: October 13, 2010, 08:51:26 AM »
Junkyard, wanted ads, dealer.
Oh, wait, are you talking about the "ball" that is the pivot point of the tranny shifter?  If so, there isn't a cup that goes under it...there is just one on the top side of the ball.
« Last Edit: October 13, 2010, 08:54:45 AM by Skyhiranger »
« Reply #6 on: October 13, 2010, 11:58:50 AM »
Hawk Suzuki is a great place to call if your missing random parts.
As for the bell housing being full of mud, do you have the metal cover plate that goes just under the oil pan and in front of the flywheel?
Offline JNM78
  • 14
  • " I like mud"
« Reply #7 on: October 22, 2010, 04:20:14 AM »
 No, theirs not one there, I thought the 5sp. did not have a dust shield, I can make one, I'm looking for metal/alum. to make skid plates now to try and help this problem.
« Reply #8 on: October 22, 2010, 04:53:06 PM »
I believe they all have a dust shield.  I know my 4 speed and the trackers do.  Not sure about a Sammy though, as I don't have that particular model.
If not I would put something on there.
« Reply #9 on: October 22, 2010, 06:05:29 PM »
samurais have dust shields.
Offline joesteak
  • 74
« Reply #10 on: October 30, 2010, 04:49:59 PM »
The mud is a killer.  I had the same problem with mine not wanting to go into 1st gear and it was because my throw-out bearing was shot from mud getting in there.
