91 EFI hesitation help
ingler99
9
November 05, 2011, 06:09:35 PM »
I have a 91 samurai that has EFI it has a header and the cat has been removed but it is very sluggish when you first take of or when throttle is barely opened. I replaced plugs wires fuel filter and air filter with no noticeable change it also seems worse when it is cold outside but it won't light check engine light so I am at a loss anyone know where to look?
mrfuelish
2862
13
you must have a perception problem.
Re: 91 EFI hesitation help
November 05, 2011, 09:22:36 PM »
I would first make sure that it has a 02 sensor and that the connection is good to it and then see if you have a tps and that it is in the right place with a volt-ohm meter.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
ingler99
9
November 05, 2011, 11:46:10 PM »
it has both so i will check into both for errors thanks
rbparker
120
Reply #3 on:
November 06, 2011, 07:15:58 AM »
Mass air flow sensor may be another suspect.
mrfuelish
2862
13
Reply #4 on:
November 06, 2011, 01:18:05 PM »
I Think he has a MAP sensor.
