91 suzuki samurai code 17
  • 3856 Views
« on: December 26, 2010, 09:59:48 AM »
91 suzuki samurai I put the fuse in and jumped the plug by the battery and got the light to blink 1 and then 7  which Ive been told is a 17. any help on what this is. As I said in the other post it has no spark at the coil. Thanks bob
Re: 91 suzuki samurai code 17
« Reply #1 on: December 26, 2010, 11:42:18 AM »
Code 17 isn't a valid code.  Either you read it wrong or there is something really messed up.
« Reply #2 on: December 26, 2010, 12:12:38 PM »
It would blink once then pause and then blink 7 times. And then in would keep repeating that. I hope I was jumping the  right 2 wires.
« Reply #3 on: December 26, 2010, 12:20:14 PM »
Is it maybe 71, instead of 17?  Because 71 is a valid code.  It is a test switch terminal error code.  Which means you have driven it at a speed above 25mph with the jumper in place.  Remove the jumper, when you are driving.
  • 6573
  • 66
« Reply #4 on: December 27, 2010, 08:05:53 AM »
There's a list of codes on our "Tech Specs" page which you can find right about in our header links...
http://www.zukiworld.com/main_departments_techspecs.htm
Good luck! -Eric
« Reply #5 on: December 27, 2010, 06:13:31 PM »
Thanks I've got some used parts coming so I'll plug and play till it starts.
