93 sidekick is killing me
  • 26 Replies
  • 7676 Views
Re: 93 sidekick is killing me
« Reply #15 on: April 08, 2012, 03:17:46 PM »
Yes i seen that-ty
« Reply #16 on: April 08, 2012, 04:17:39 PM »
The left side rear tailight wiring area also has the ground for the fuel pump, but you said you looked at that.
« Reply #17 on: April 09, 2012, 07:22:06 PM »
yes,i ran a new ground to get my lights working,so that's not the problem-lol
« Reply #18 on: April 10, 2012, 02:36:27 PM »
Buddy, I feel for ya. There's nothing more frustrating ( to me anyway )  than trying to trace an errant electrical problem. Sometimes I think these things may be haunted. Hang in there, you'll get it eventually or you can just say screw it and run a switch like you mentioned! :laugh:
« Reply #19 on: April 10, 2012, 07:59:12 PM »
So true!!!! I will keep you updated and thanks for the help!!!!!!!!
« Reply #20 on: April 11, 2012, 09:07:41 AM »
Do you have voltage when you first turn on the switch?  The fuel pressure switch will disable the fuel pump if it does not have adequate pressure after the initial 2-second burst.
« Reply #21 on: April 11, 2012, 07:45:29 PM »
I have power at the main relay but not at the fuel pump relay
« Reply #22 on: April 16, 2012, 09:01:46 PM »
I gave up and taped the relay-lol
« Reply #23 on: April 17, 2012, 03:51:56 AM »
Whatever works!  ;)
« Reply #24 on: April 18, 2012, 08:09:54 PM »
lol-so true so true
Offline Zuki-Girl
  • 128
« Reply #25 on: April 19, 2012, 11:59:40 AM »
Nobody mentioned this,so I will. On the dist there's a ground wire that goes to the firewall,did you check to make sure it's connected?
« Reply #26 on: April 20, 2012, 05:31:49 PM »
unfortunately yes-lol-I appreciate the tip  :)
