95 tracker lost key, key code??
  • 4471 Views
« on: July 17, 2012, 11:11:49 AM »
I lost my key and want to just get a new one made, GM said they could make me a key for 8 bucks if i get the key code, some people are saying its on the lock barrel on the passenger side, some say drivers side,  this is a US car,  how many digits is the code? what should i be looking for?? thanks!
Re: 95 tracker lost key, key code??
« Reply #1 on: July 17, 2012, 04:20:43 PM »
luckily the key code was on the passenger side lock, two nuts and a clip to remove it, simple, took it to chevy and they cut it for 3.50
Offline mike5721947
  • 545
« Reply #2 on: July 17, 2012, 09:31:19 PM »
i got mine off my vin for my sidekick. was at suzuki and got the code and a nice new key blank (with the black grip with suzuki embosed) then just had to take the code to get it cut (dealer didnt have the machine) had a gm dealer cut it no problem.
factory key i had from when i got the truck was pretty worn out so a copy wouldnt have been good enough
i think the key blank cost me 8 bucks cnd. cutting was nothing.
31" kumhos 3inchs of lift.
« Reply #3 on: July 18, 2012, 07:24:07 AM »
Just so you're aware of it - it's not just the key that wears, the tumblers in the lock also wear with usage - I have a factory key that has only been used to make copies, and copies made from that key now have to be deliberatly "over cut" for them to work.
Offline mike5721947
  • 545
« Reply #4 on: July 18, 2012, 09:17:29 AM »
yes, but tumblers wear larger, the key wears smaller. with a new key cut to proper spec it would get it closer to stock. i know i need to pull my ignition out and get it rebuilt because of wear. but the new key lasted for 3 years on the old tumblers.
truck has 375,000km on it so i expect wear and tear on the small stuff.
Offline airdreams1
  • 90
« Reply #5 on: July 20, 2012, 10:59:51 AM »
Just go to the wrecking yard & find the door locks from several newer cars & remove the wafers... pull you old ignition & replace with the matching wafers.........   youl have a good working ignition again.
87 Samurai  soft top
