96 Sidekick JX 2 door4x4
  • 1254 Views
Offline DesertFox48
  • 6
« on: August 26, 2021, 09:49:58 AM »
Hi Guys,
I am looking for a rear drive shaft for my Sidekick. It is an AT and the rear shaft. I don’t care if it is used or new. Any ideas as to where I can get one. Thanks.
Offline Dughrt
  • 40
Re: 96 Sidekick JX 2 door4x4
« Reply #1 on: August 26, 2021, 02:03:31 PM »
Depends on your location. I have one in Oregon, there is a guy near Tacoma that has alot of parts. Hwy 83 Suzuki sells alot of used parts, Also trail tough has some used stuff. Heck even try your local pick a part yard.
Offline JollyZuk
  • 284
« Reply #2 on: August 26, 2021, 06:15:53 PM »
What has happened to your existing shaft?  Double check my info, but I believe you will need to make sure you get a shaft for a 96+ rig, because the outputs on the transfer case changed in 96.
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline DesertFox48
  • 6
« Reply #3 on: September 04, 2021, 08:05:20 PM »
DUGHRT
How much do you want for the drive shaft? I will buy it from plus shipping of course.
Offline DesertFox48
  • 6
« Reply #4 on: September 04, 2021, 08:07:04 PM »
JOLLYZUK
When the old drive shaft gave way it hit pavement pretty badly and is all tore up on the ends.
