99 GV Timing Chain
  • 1977 Views
99 GV Timing Chain
« on: July 15, 2010, 04:33:49 AM »
Any of you had problems with the timing chain on your Grands?  Mine makes a little noise and I read online that they had some issues with guides wearing out...Not sure what to do.   I don't want to if its not necessary.  Thanks.
Re: 99 GV Timing Chain
« Reply #1 on: July 15, 2010, 04:34:17 AM »
I should have specified I have the 2.5L V6.
« Reply #2 on: July 18, 2010, 10:51:39 AM »
I know the 2.0L have issues if you don't use the correct weight oil and it causes the guides to wear out early.  Hopefully someone with that generation of vehicle will add something.
Offline losidriver2003
  • 79
« Reply #3 on: July 18, 2010, 03:39:08 PM »
maybe this would do better in the gv section .
01 xl7 calmini susp rro body lift 225 75 16 tires
« Reply #4 on: July 19, 2010, 09:21:47 PM »
Stick with the 5-30w oil, timing chain stretch and guide wear are
the symptoms of using too heavy oil
