AC - how cool ?
  • 1568 Views
Offline my996duc1
  • 222
AC - how cool ?
« on: May 04, 2010, 04:07:02 PM »
I am running a 1.6 16v out of a 1998 X90 in my 1987 Samurai. The ac system was converted over to R134 at the time of engine swap over a year ago.
I turned the ac on the other day to try it and it doesn't feel very cool.
How cool should this thing run at the vents ??
Thanks !
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Re: AC - how cool ?
« Reply #1 on: May 04, 2010, 07:17:23 PM »
You have to put gauges on it to check for the right amount of R-134
The engine RPM and air flow will make a big difference in the output temp
Re: AC - how cool ?
« Reply #2 on: May 08, 2010, 04:07:58 AM »
Mine only gets " cool " while I'm moving along , at least somewhat forward. The thing never really got " cold." Sure beats sweating your ass off in the northeast heat and humidity in the summer though!
Offline my996duc1
  • 222
Re: AC - how cool ?
« Reply #3 on: May 08, 2010, 05:16:15 AM »
got it charged up and they put a dye in it to see if it has any leaks.
It got down to 52 degrees at the vents...alot better than what it was but not as cool as I wanted.
Now just gotta take it back in next week to see if it is leaking.
