Help!! Samurai won't pass smog
  • 2908 Views
« on: October 07, 2009, 06:27:35 PM »
Took it for a pre inspection today and failed. Its running way to rich. It is 4 times the state requirement. How do i lean out the carb? Also how do i adjust the valves?
Re: Help!! Samurai won't pass smog
« Reply #1 on: October 08, 2009, 08:37:23 AM »
When was the last tune-up you have done on the Sammy?  A new set of plugs, wires and a cap/rotor combo could make a huge difference when it comes to meeting the local requirements.  Cleaning your carb also wouldn't be a bad idea.
Do you still have a Catalytic Converter on your Sammy?
Did you have a problem with CO emisions?  Of so Acks Faq has a PDF that covers this issue.
http://www.acksfaq.com/pdfs/samuraicarb.pdf
If you do a search over there (http://www.acksfaq.com) for carb there are quite a few tune-up articles.
Offline RJkick
  • 634
« Reply #2 on: October 08, 2009, 12:22:15 PM »
Offline jaunty
  • 48
« Reply #3 on: October 08, 2009, 05:45:06 PM »
I failed smog this morning:
HC - 280, limit is 220
CO - 1.76, limit is 1.0%
I went home, turned in the mixture screw until rough idle, out a little bit, still a little rough but not too bad.  I took it through again, making sure i got the catalytic converter real hot.
BAM
HC - 15!
co - 0.0 %
YEEHAW
turned out mixture screw again, slightly IN compared to what it originally was.
