buzzing no blinkers
buzzing no blinkers
zukiking
89
buzzing no blinkers
February 06, 2012, 06:41:05 PM »
Ok guys My zuk has a problem. When I turn my blinker to the left it stays solid and buzzes when I turn it to the right nothing. The buzzing is coming from the relay beside the fuse box. Any ideas would help.
beagle..t
1239
16
Re: buzzing no blinkers
February 06, 2012, 08:00:55 PM »
my tracker 91 has a buzzing when i turn left side on ...u could try changing the fuse that buzzes and check your ligts thats all i can think of
V6 swap auto ,2 dr ,2" BL,2" jeffs kit 512 gears warn hubs and 30/9.5/15 BFG AT
zukiking
89
February 07, 2012, 06:49:11 PM »
ok i really need help with this, its my flasher that is buzzing ive replaced it and its still doing this
biker
730
7
It's a sickness I tell ya
Reply #3 on:
February 07, 2012, 07:01:08 PM »
The problem is in the signal switch. Either take it apart and try to clean it up or just get another multi switch, probably easier
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
zukiking
89
Reply #4 on:
February 07, 2012, 08:39:47 PM »
have you ever cleaned one im just curious of how to do it. Ive looked at a lot of posts but none that show this.
biker
730
7
Reply #5 on:
February 08, 2012, 06:46:05 AM »
I haven't but heard of others trying it with mixed success. I just put a new switch in.
99 Vitara 2wd
10 Gr Vitara
