bleeding brakes
  • 21 Replies
  • 4439 Views
Offline grats
  • 28
Re: bleeding brakes
« Reply #15 on: July 20, 2010, 09:40:04 AM »
Yes, but to replace the bleeder you have to buy the whole brake cylinder. It comes attached when you buy one.
1982 SJ410
1997 Tracker
2008 SX4
Re: bleeding brakes
« Reply #16 on: July 24, 2010, 12:34:58 AM »
That is correct, bite the bullet and replace them, unless you can remove
and replace the bleeder, replace the wheel cylinder
Re: bleeding brakes
« Reply #17 on: July 24, 2010, 06:04:34 AM »
Offline jow003
  • 403
Re: bleeding brakes
« Reply #18 on: July 27, 2010, 06:22:15 AM »
took off the hub and everything was nasty as you can see in the pic, put a little fluid in and pushed the brake pedal and you'd a thought there was a water gun in there it sprayed so bad.  got a new one, $15 at autozone, and so far so good.  any ideas on how to get a bleeder off/out when its been stripped by box end/vice grips?
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: bleeding brakes
« Reply #19 on: July 27, 2010, 06:41:17 AM »
I'd use an "easyout" or something similar - start by very carefully drilling the hole in the bleed nipple larger & larger until you get the easy out in.
Or just replace the entire wheel cylinder.
Offline jow003
  • 403
Re: bleeding brakes
« Reply #20 on: July 27, 2010, 06:54:21 AM »
i thought i had to get it off to replace it, may just do that and save the headache.  my first one took 2-3 hours, 2nd only about 45min
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: bleeding brakes
« Reply #21 on: July 27, 2010, 08:23:43 AM »
Go to autozone and get them to look up the part, then take a look at it
so you know what it looks like and how it's all together, like the bleeder
is part of the wheel cylinder.
That's why we kept telling you to just get a new wheel cylinder, it is the
fast easy way to fix your problem, but if you want to do this the hard way
I won't stand in your way  ;) , You asked for help, and the best way was
given, but you have to follow the suggestion or beat your own path, the
choice is yours, and a learning experience along the way
