Brake drums and shoes for 83 sj410
  • 16 Replies
  • 7793 Views
Offline ontario410
  • 32
« on: August 06, 2025, 01:26:47 PM »
In looking for brake drums and shoes for my 83. Are they different over the years or will all of the samurai years fit?
I'm also looking for an aftermarket steering damper
  • 6602
  • 69
Re: Brake drums and shoes for 83 sj410
« Reply #1 on: August 09, 2025, 10:42:13 AM »
They are different and the 'samurai' brakes won't fit. You may be better off sourcing Samurai axles and swapping those in. Bigger parts and a little wider stance. The spring pad location is the only issue.
Offline ontario410
  • 32
« Reply #2 on: August 10, 2025, 06:18:10 AM »
Crap. I was told that they would prior to seeing your response. I ordered a set of drums and shoe from suzukipartsusa. I sourced a Monroe steering damper that does look like it will work. I will list the part number if it works for others to reference
« Reply #3 on: August 10, 2025, 06:18:40 PM »
For future questions of this nature, go to megazip.net and use their parts search facility, you can enter your vehicle chassis number or navigate you way through the pages to find what you want.
If the part numbers match, they will interchange, if they are different, they may or may not.
Offline ontario410
  • 32
« Reply #4 on: August 11, 2025, 05:01:29 AM »
Okay thank you for the info I will defiantly do that. On another note the Monroe steering damper fits pretty well and the vehicle driving difference is like night and day.
Offline ontario410
  • 32
« Reply #5 on: August 15, 2025, 07:08:57 PM »
So the drums do not fit as you stated and the shoes while they look the same do not have the elongated holes on the bottom for the bottom springs. I may be able to drill a hole but don't really want to. I found a local guy who will turn the drums for me now I just need to email megazip and see if they have parts. There seem to be alot of variations of the sj410 on there. I might tryand see if I can research their database by chassis number
« Reply #6 on: August 16, 2025, 06:29:44 AM »
You can also take a look at Partsouq.com - I find megazip easier to search, but partsouq will generally have better pricing.
Offline ontario410
  • 32
« Reply #7 on: August 17, 2025, 06:58:57 AM »
Awesome. Thank you for the resource I will take a look. The shoes were listed as for the vehicle . Got them from Suzukiparts USA. But they do t have the lower openings to accept the bottom springs off the tensioner. Other wise they look identical
Offline ontario410
  • 32
« Reply #8 on: December 03, 2025, 05:56:06 PM »
Well I ordered brake shoes from mega zip a few weeks ago and now got an email saying they are no longer available? I'm hoping it's not permanent.
Offline ontario410
  • 32
« Reply #9 on: January 01, 2026, 09:48:01 AM »
Looks like the shoes are no longer available on partsouq or megazip. Does anyone know of any aftermarket brake shoes for 1983 model rear brakes. I suppose I could try and find someone to re line my shoes if that is even a thing any more
Online ButchW
  • 45
« Reply #10 on: January 01, 2026, 09:51:14 AM »
Man I haven't thought about shoe relining in years... Good luck on your quest, and Happy New Year...
Butch
  • 6602
  • 69
« Reply #11 on: January 03, 2026, 09:05:49 AM »
Just a thought... How about grabbing all of the parts from a SJ413/Samurai? If you get all the outer stuff, you'd be able to use Samurai brakes, right? -Eric
Offline ontario410
  • 32
« Reply #12 on: April 04, 2026, 04:22:53 PM »
Sorry for the delay. I got 2 sets of shoes from Australia .I am gonna have a look at it in the next few days. I will let you know if they are compatible. Also if any one needs rear drums and shoes for an 85 and newer I have a set that I dont fit my 83
Offline ontario410
  • 32
« Reply #13 on: May 25, 2026, 02:19:01 PM »
So I replaced the shoes and cylinders from ones I got from Australia. One side has the star wheel adjuster on the bottom and an adjuster assembly up top by the cylinder is this correct? It appears the previous owner installed backwards from what I can tell and for the life of me I can not get it back in and make it work without the shoes lifting away from the backing plate
  • 6602
  • 69
« Reply #14 on: July 12, 2026, 07:34:41 PM »
I don't know if you'd be interested in this or not but I have a complete front and rear SJ410 axle set. Drum to Drum front and rear... I have no use for this! If you're interested, I'll make you a heck of a deal.
