Shackle info needed
Shackle info needed
SIDEKICK65
176
Shackle info needed
June 25, 2012, 11:37:19 PM »
I did a sas swap on my sidekick.now i need to install the shackle's. I used yj leaf's and im putting the shackle's on the rear of spring's.but what i need to know what angle ill need to install the shackle's.
Drone637
8121
116
Evil Cow
Re: Shackle info needed
June 26, 2012, 03:45:26 PM »
Are you installing new upper mounts? How long of shackles are you using?
SIDEKICK65
176
June 27, 2012, 01:25:45 AM »
I'm using boomerang shackle's that are 4 7/8 form hole 2 hole.The top mount's will go threw the frame.
Drone637
8121
116
Evil Cow
Reply #3 on:
June 27, 2012, 11:14:06 AM »
Here is a good article on shackle info:
http://www.quadratec.com/jeep_knowledgebase/article-93.htm
I always tried to set them up so I had decent movement but they couldn't fold back on the frame and bend the spring. Not the most exact science.
SIDEKICK65
176
Reply #4 on:
June 28, 2012, 01:54:43 PM »
Hey thank's drone on the shackle info.
