Calmini SR
  • 13 Replies
  • 4404 Views
Offline Cylon
  • 20
  • 1988.5 Suzuki Samurai......My Project.
Calmini SR
« on: May 17, 2010, 08:05:16 PM »
My Calmini SR sits about 1' lower in back what can I do to even it out? how long of a shackle do I need for the rear?
Offline woof359
  • 111
Re: Calmini SR
« Reply #1 on: May 17, 2010, 08:27:43 PM »
CR ?
CHUCK AND MICHELLE
Offline djlantis57
  • 871
  • Take your chrome home
Re: Calmini SR
« Reply #2 on: May 18, 2010, 01:04:45 AM »
I think he's talking about a shackle reversal
  • 6587
Re: Calmini SR
« Reply #3 on: May 18, 2010, 06:19:26 AM »
You're all set up for desert scootin' now! But seriously, the stock kit does usually result in the rear being lower than the front. A rear shackle that is 1.5" longer than the one provided will get you in the ball park. Of course this depends on what you have in the back of the vehicle as far as weight and how roached your springs are.
Offline djlantis57
  • 871
Re: Calmini SR
« Reply #4 on: May 18, 2010, 10:27:49 AM »
True that.  Got a question for you: is it a tintop or convertible?  Cause I'm thinking that weight can make a difference.
I'm thinking you meant 1" instead of 1'.  Because if you were 1' low in the back then I would say you might be MISSING your leaf spring entirely  :laugh:
And, does anyone else have this problem with the shackle reversal?  Because it comes with a rear shackle kit, too, right?
I've been thinking about doing this and 235's if and when I get a Samurai in addition to keeping my Tracker.
« Last Edit: May 19, 2010, 10:21:39 AM by djlantis57 »
Offline Cylon
  • 20
Re: Calmini SR
« Reply #5 on: May 18, 2010, 12:56:54 PM »
Soft top and yes it comes with a rear boomerang shackle it isnt really noticeable but it does sit lower Im not sure how long of a shackle I need in the rear to make it sit even, Im thinking the missing link and a 2' lift shackle will do it.
Offline woof359
  • 111
Re: Calmini SR
« Reply #6 on: May 18, 2010, 06:00:23 PM »
Man I need to proof read before I post, sorry about that, I did wonder what the reverse shackle ment and there boomarang design. In about a week Ill be ordering some suspension from Calmini, just not sure there 3 inch lift kit, well make 235's clear with out triming, do i nee to go 5 inch ?
CHUCK AND MICHELLE
Offline djlantis57
  • 871
Re: Calmini SR
« Reply #7 on: May 18, 2010, 06:47:06 PM »
Can you post a picture?  I'm really curious to see how it sits right now with the shackle reverse kit and rear boomerang shackles
Re: Calmini SR
« Reply #8 on: May 19, 2010, 05:11:28 AM »
If I remember rightly the SR kit is supplied with 1" lift shackles (2" longer) for the rear but the front end is lifted 2" by the SR itself, always struck me as a bit odd.
  • 6587
Re: Calmini SR
« Reply #9 on: May 19, 2010, 07:50:51 AM »
I run 30x9.5 BFGs on stock rims on a Samurai w/the shackle reverse lift only. Now trimming other than a little of the stock bumper end and hammering the seam on the rear of the front wheel well.  No rubbing.... As stated above, I do have a 1.5 longer shackle than the boomerrang to level the ride.
Offline Cylon
  • 20
Re: Calmini SR
« Reply #10 on: May 19, 2010, 02:59:04 PM »
Offline Cylon
  • 20
Re: Calmini SR
« Reply #11 on: May 19, 2010, 03:03:14 PM »
Eric where did you buy your shackle or if you made it can you post me to a link where I can buy the proper shackle?
  • 6587
Re: Calmini SR
« Reply #12 on: May 19, 2010, 03:05:22 PM »
Sure... the one that's on the car is from Calmini. I'm not sure if they still make them or not... Give them a call. It's straight and about 1.5" longer than their standard boomerang shackle.
Offline woof359
  • 111
Re: Calmini SR
« Reply #13 on: May 19, 2010, 06:37:00 PM »
when it came time to installed the Calmini shackles, were they rusted in the leaf's ?
CHUCK AND MICHELLE
