Ceap power?
  • 18 Replies
  • 4118 Views
Offline 87Suzi
  • 156
  • Love this little thing!
Re: Ceap power?
« Reply #15 on: February 12, 2012, 05:16:54 PM »
could I changer the gearing for more pull power?
Offline Boxcar
  • 936
Re: Ceap power?
« Reply #16 on: February 12, 2012, 05:21:08 PM »
Yes. A pacesetter is fine.
 As to the cat.....Run her if you have to. If its just a visual inspection though , you can allways blow out the cat
and run it as a resonator....Boxcar...
God Bless
Offline 87Suzi
  • 156
Re: Ceap power?
« Reply #17 on: February 14, 2012, 08:11:18 AM »
If I order my engine rebuild kit from lowrange should I just go with the OEM style pistons or is it worth the extra $100 to get the high compression pistons and will that just make it have more nuts on take off and hills or an all around boost in power? Thanks
Offline Boxcar
  • 936
Re: Ceap power?
« Reply #18 on: February 14, 2012, 01:46:33 PM »
Hi comp pistons will defiantly increase HP # . Just make sure that you replace all the head bolts with new ones....Boxcar...
God Bless
