Grand Vitara rearend/rear axle whine
  • 3047 Views
Offline phunon
« on: October 15, 2009, 07:27:45 PM »
My 02 GV, 4x4, has a very noticeable whine in the rear.  Sounds like left rear.  Tires OK.
What do you think?
  • 6601
  • 68
Re: Grand Vitara rearend/rear axle whine
« Reply #1 on: October 19, 2009, 09:41:07 AM »
What do you think?
Hi pitched whine or lower pitched growl? Does the noise change if you are driving left vs. right vs. going straight? Jack vehicle up and see if the wheel/tire can be wiggled. If it is loose, this may suggest a rear wheel bearing is going out.
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: October 21, 2009, 11:14:30 AM »
If it goes away when you let off the gas, your diff might be set up wrong as well.
Offline phunon
« Reply #3 on: October 22, 2009, 06:12:44 PM »
Yes, sound seems to go away when I let off gas.  Same sound straight or turning.
