Blower motor resistor
  • 2890 Views
Offline hwyman
  • 175
« on: December 04, 2015, 05:28:56 AM »
If the blower motor resistor goes bad will I loose all fan speeds for my heater?
I have checked the fuse and its good, I had to super glue the fan switch about 18 months ago and pulled it out thinking I needed to reglue it but it is still glued together
what else do I need to check?
Travis
1994 Geo Tracker  2dr 4wd 1.6l 8v Manual Trans
Re: Blower motor resistor
« Reply #1 on: December 04, 2015, 07:18:43 AM »
Time to get out a meter and check for voltages - the switch could be in one piece & defective, or the motor brushes gone, or...
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #2 on: December 06, 2015, 02:35:32 PM »
Travis
Yes, that is what happened to me.  Periodically I would lose my blower motor on any fan setting... then it would suddenly start again.  Finally, early last summer it quit completely, in the dead of heat of the summer.  I replaced both the resistor and the fan motor while I was repairing it.  My fan motor had been making noises for a while as well.  I have the fan on virtually any time I was in the truck... so it had been ran A LOT.
The resister is far easier to replace than replacing the blower motor.  There are three crews holding the blower motor in the housing.  The screw that is up against the firewall is a BEAR to access.
On the Wrangler I bought last June the fan only operated on the two highest settings.  I replaced the fan resister for $20 and all is well on it now too.
« Last Edit: December 06, 2015, 02:39:14 PM by nprecon »
« Reply #3 on: December 06, 2015, 05:05:00 PM »
The fan SHOULD run on the highest speed with a defective blower motor resistor (or even with no blower motor resistor) - in that position the switch completely bypasses all three sections of the resistor effectively removing it from the circuit.
