What is the best way to get the "milkshake" out after head gasket replacement
  • 1066 Views
Offline RJkick
  • 634
Only thing I know of is run a couple oil changes through (oil and filters) - I'm thinking 2 and make the 3rd the final oil change
I heard something about Mysery oil or something like that but not sure
Any thoughts
Offline c3006
  • 263
  • 10
I drain the filter that was on it and wash it out with a little gas then put it back on and run the cheap Walmart oil $13 a gallon for a complete heat cycle.  Then drain and put on a new filter with good oil and have never seen a bit of contaminated oil after that.  c
Offline RJkick
  • 634
thanks
