need some help
  • 2273 Views
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
need some help
« on: April 08, 2010, 12:27:00 PM »
ok where the steering stabalizer attaches to the cross member in front where the tow loop is.  I need someone to measure from inside of frame to where the stabilizer attaches to see the distance.
Also do you think if I drilled a hole with a bolt running through the new cross member I made and attach the steer stabalizer to that if it would be strong enough?
Offline creepy crawler
  • 14
  • I Love DLROWIKUZ
Re: need some help
« Reply #1 on: April 09, 2010, 04:51:28 AM »
   7 1/2 in.. And i would think it would be strong enough. There's no real heavy pressure transfered through a stabalizer. But you could run a small tubing sleeve for the bolt to pass through the main crossmember tube. If that's how your going to mount it.
''Where goin back to the moon.'' G.Bush Jr.         Yea,whatever. You old groovy cowboy you.
Offline Amilla
  • 1076
Re: need some help
« Reply #2 on: April 15, 2010, 10:55:45 PM »
A bolt would be plenty strong.  Universal stabilizers normally come with funky U-bolt style mounts.
Seen quite a few people running that style with no problems.
Amilla
Re: need some help
« Reply #3 on: April 18, 2010, 09:18:36 PM »
If you switch to a Toyota stabilizer it is longer by several inches and gives you more wiggle room when it comes to mounting.  I run mine from the pitman arm over to the frame on the opposite side.
Offline john1974
  • 617
    • Zuknation
Re: need some help
« Reply #4 on: April 22, 2010, 07:38:38 AM »
What I did was cut the old bracket off and welded it to the new bar I put in.
