Duty Check Coupler?
Duty Check Coupler?
kelly mt
22
The Samurai on The Mountain
Duty Check Coupler?
October 06, 2011, 08:28:27 PM »
What is the Duty Check Coupler used for?
mrfuelish
2862
13
you must have a perception problem.
Re: Duty Check Coupler?
October 06, 2011, 09:05:27 PM »
to set your idle air adjustment.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
kelly mt
22
October 06, 2011, 09:26:01 PM »
What do you plug in? I haven't got that far in the maintenance book. Ran across it while looking for a switched source for my tach. PK
fordem
4333
170
Reply #3 on:
October 07, 2011, 04:50:04 AM »
It may depend on the vehicle and the year of manufacture - I can use mine to "freeze" the ignition advance, allowing me to set the base ignition timing, and also to get any active CEL codes.
rascott
669
15
tread lightly monkeywrench a little
Reply #4 on:
October 07, 2011, 10:09:50 AM »
i have used the connector to adjust the idle mixture(after removing the anti-tamper pin).
i used a dwell meter..... not a quality unit, but it did act as the manual predicted.
i have the carbureted sidekick, but i expect it's similar to the samurai.
