Front axle shakes
  • 1882 Views
Offline Alexanselmo8
  • 82
  • 2002 Chevy tracker 4-door ZR2 2.5L
Front axle shakes
« on: August 17, 2015, 02:29:23 PM »
My front tires will both shake at random points, even on the highway, and i feel my car vibrating, i have replaced both cv axles and also replaced both wheel hub assemblys, the calipers both are in good shape and dont stick, so my only other thought is something has gone bad in the axle. I did notice when i was replaceing my front passanger cv shaft that when  would spin it you could hear a ticking in the axle housing. Any info is very much appreciated
Re: Front axle shakes
« Reply #1 on: August 17, 2015, 03:54:40 PM »
Out of balance tire/wheel assemblies, bent rims, bent tires, ball joints, control arm bushes, steering rack ends, steering rod ends - and for that ticking in the axle housing - there is a bushing/bearing in the back of the spindle.
Offline beagle..t
  • 1239
  • 16
« Reply #2 on: August 17, 2015, 09:43:58 PM »
ya like fodem said can be all what he said.... but I would check the rims and tires first
« Reply #3 on: August 18, 2015, 05:48:18 AM »
That's why the rims & tires were first in the list  ;) just swap them front & back, see if the symptoms change.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #4 on: August 18, 2015, 07:28:42 AM »
I owned a set of Coursers a few years ago.  A great tire... except when I drove interstates.  At right around 65-70MPH I would suddenly feel a large vibration.  Beyond 70MPH it disappeared completely.  At any other speed and at no other time had I ever had any issues with the tire.  They still had 80% tread life remaining.
The first time it occurred, I actually stopped my truck (quickly) to see if one of my tires had come loose. The vibration was that bad.
It happened to me on two other occasions with these same tires.  Rotating them didn't give me any assurances.  I trashed the tires and bought new ones.
