Gauges don't work
  • 1070 Views
Offline weldboy
  • 91
  • I'm only here for the carnival atmosphere !!!
Gauges don't work
« on: November 04, 2010, 03:47:20 PM »
I just installed a Adventure Offroad GM CS130 Alternator kit off of ebay. On my 86 Samurai ,I supplied my own new alt. I've read there wiring plug doesn't sense the voltage and i need to rewire the Blk/Wht wire. But now i've noticed my temp gauge sits on the bottom and my gas gauge sits pegged at the top. They were working fine before I changed over, any ideas ???? ???    Thanks
Re: Gauges don't work
« Reply #1 on: November 04, 2010, 04:38:31 PM »
Sounds like you disconnected a ground wire.
Offline z3ro
  • 339
« Reply #2 on: November 06, 2010, 05:03:01 PM »
Check these out, and make sure you wire your alt according to the second diagram.  You'll have the most success this way.  As I understand it, the kit you bought has a plug that utilizes the fused/switched circuit in the factory wire harness.  You don't want to use that or you'll over/under charge (because sammy wiring sucks).
If you've wired it correctly and still no gauges, post back.
http://www.zukikrawlers.com/showthread.php?s=386ee49471003465310e24730cb7b416&t=30128&page=2
