Wiring problems! help
  • 9 Replies
  • 3173 Views
Offline jrok90
  • 17
« on: December 20, 2011, 08:26:58 PM »
Just got a 90 samurai,  its got some wiring problems.
the green wires on the brake pedal switch have been melted
the blower motor is not plugged in, not sure where the wires are for it.
fuel pump has been wired on a separate switch
any help would be greatly appreciated!
Offline mrfuelish
  • 2862
Re: Wiring problems! help
« Reply #1 on: December 20, 2011, 08:41:42 PM »
on the two wires that are melted I would start off by putting a buzzer of some kind pizzo etc. hooking it to the wires (hook two wires from buzzer to each of the melted wires) and start pulling bulbs in the back and moving wires around until buzzer goes out.
Offline jrok90
  • 17
« Reply #2 on: December 21, 2011, 02:37:26 PM »
dug out the green wires cut them off where they were still good, so I will have brake lights
I think i am missing the turn signal relay, should it be to the right of the fuse block??
still not sure about the blower motor.
Offline mrfuelish
  • 2862
« Reply #3 on: December 21, 2011, 10:08:58 PM »
I think mine goes in the fuse box, has to be a square blinker relay to fit good.
Offline jrok90
  • 17
« Reply #4 on: December 22, 2011, 04:52:35 PM »
got blower resistor ordered (it was missing for some reason)
I have tail lights, brake lights NO turn signals
when I installed the flasher and tested the wire with a test light it buzzes instead of flashing.  not sure what to try next.
« Reply #5 on: December 22, 2011, 07:26:33 PM »
Trace the turn-signal wiring - there's a short to ground somewhere.
Offline jrok90
  • 17
« Reply #6 on: December 22, 2011, 09:03:29 PM »
hazard flashers work, had to put a larger load on it to make it flash (test light was not a big enough light)
turn signals still don't work
does that mean I need to replace the whole turn signal-headlight switch assembly on the steering colum??????
« Reply #7 on: December 23, 2011, 07:33:06 AM »
Not necessarily ...
In fact - I have no clue what you did check with your test light and larger load.  If you had successfully tested the hazard lights using the turn signals (rather than a test light & dummy load), then you would have eliminated a lot of the possible problem area, and I would have said you need to focus under the dash, but since I don't know where you connected what, we're still in the same position.
Go to www.acksfaq.com and get yourself a schematic for the vehicle and use that as a guide.
Offline jrok90
  • 17
« Reply #8 on: December 23, 2011, 01:46:49 PM »
i wired a light to my tail light wires on the back,  when I pull up in the hazard flasher switch they blink like they should
when I shut the hazards off and turn either turn signal on nothing happens.
since it is one unit i hope that is the problem
Offline jrok90
  • 17
« Reply #9 on: January 02, 2012, 01:28:36 PM »
got all my problems fixed!
PO had wired the brake wire and turn signal together, not a good idea
fixed melted wired going to brake switch, replaced missing turn signal flasher, replaced missing blower resistor (heater now works)
wired stereo correctly,
Lots of solder and shrink wrap and it all works and looks good now.
