Speedo Cable Help
Speedo Cable Help
CodyB
16
Speedo Cable Help
February 17, 2012, 01:33:37 PM »
I pulled my dash out of my 93 tracker and found that all of the wiring was coated in this black sludge. After doing a little more investigation I discovered that oil was being pushed up the cable tube. It also has a slight leak around the transfercase where the cable gears are located. This has me puzzled on why it is doing such a thing. Is there a seal that might be out or something? Any help will be appreciated.
LowRangeWilliam
36
Re: Speedo Cable Help
February 18, 2012, 12:57:24 AM »
your trans breather may be plugged it comes up the back side of head has a white breather cap on it
make sure the hose isn't crimped or plugged
CodyB
16
February 18, 2012, 11:30:58 AM »
Both vent tubes are unclogged
