a " registor " ?
  • 7 Replies
  • 2028 Views
Offline rockybaroofy
  • 38
  • doing what i can , with what i've got !
a " registor " ?
« on: February 18, 2012, 02:34:54 PM »
the little electrical thing with wire coils on it that mounts with one screw thru the top of the heater box  , the repair manual calls it this , but what does it do and can my zuki live with out it ?
'93 tracker pick-up daily driver
91 tracker 3"+3" 31's
Re: a " registor " ?
« Reply #1 on: February 18, 2012, 02:59:46 PM »
A "registor"?  Maybe a resistor?  There should be a resistor used to control the blower fan speeds mounted on the the blower housing, and yes, you could live without it.
Offline talonxracer
  • 1284
« Reply #2 on: February 18, 2012, 03:06:33 PM »
It is the resistor pack, the resistors lower the motor speed. You can live without it, but make sure the wires are properly connected to have a single speed fan, always on high.
I would clean the heater core.
Offline KJMac
  • 280
« Reply #3 on: February 18, 2012, 11:04:46 PM »
 So if I currently just have the 2 highest speeds, could it be the resistor or the switch? Thank you,
Kj
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
Offline talonxracer
  • 1284
« Reply #4 on: February 19, 2012, 06:03:28 AM »
It would be the resistor pack more than likely. Also I have seen many a resistor pack fail in such a fashion that you have the selector lever on high but are actually at a lower speed. Resistors fail in one of two ways, they either increase resistance or open, and usually increase resistance untill they overheat, burnout and then open.
« Reply #5 on: February 19, 2012, 06:17:55 AM »
I'd say it's a toss-up - I've seen both defective switches and resistors
Offline rascott
  • 669
  • 15
« Reply #6 on: February 19, 2012, 08:49:17 AM »
i threw that "registor" and the related harness away before i knew what i was doing. i thought it had something to do with the a/c stuff i was removing.
i now only have a high speed fan(or off, of course).
sounds like your unit went bad. should be able to check switch function at that connector?
i may try a resistor pot for regaining control- could work?
« Reply #7 on: February 19, 2012, 11:47:31 AM »
If you could find the right resistor pot, it would, but the chances of that happening are slim to nil - you'd need a low resistance, high wattage wire wound potentiometer - what's more commonly known as a rheostat, and finding a rheostat with a low enough resistance won't be easy, or cheap.
Go get a switch & resistor from the junk yard - it'll be easier & cheaper.
