Turns over but won't start PLEASE HELP?
  • 1462 Views
Offline MC project
  • 6
« on: December 06, 2009, 08:47:18 PM »
Okay I have already checked the obvious spark plug, ignition wires, fuel but in my 1990 sidekick that has been sitting for probably 2 years and not started in about 6 months I kind of need someones direction am I missing something? I have to admit I am not an auto mech. but not afraid of working on my own stuff but kinda need some guidance.
Offline captchee
  • 224
Re: Turns over but won't start PLEASE HELP?
« Reply #1 on: December 07, 2009, 05:41:08 AM »
1) do you have  visible  spark , fuel and such ?
2) check and make sure you Cam is turning  when you crank the engine . .  Just take the  oil cap off and look down inside .
 You may have thrown the timing belt .
3) check and clean your grounds . On  on the firewall . My 89 also had one on each finder and  another back  behind the drivers taillight .
 Make sure they are all clean  and grounding well
« Reply #2 on: December 07, 2009, 07:20:02 PM »
Maybe the caps in the computer popped and corroded the traces on the board
Offline ranger88den
  • 279
  • 12
« Reply #3 on: December 09, 2009, 12:58:31 PM »
Bad Gas?
Offline dres0081
  • 73
« Reply #4 on: December 10, 2009, 10:17:21 AM »
does it even try to turn over or is the starter not kicking in?
88 1/2 sami,yj springs spoa, 33s
Offline MC project
  • 6
« Reply #5 on: December 10, 2009, 08:10:39 PM »
No it turns over just won't start.. I am beginning that it might have something to do with the fuel injectors but have to wait until the weekend to figure out..
