Help a new owner with some mods
  • 2272 Views
Offline pm6214
  • 10
« on: February 14, 2012, 04:16:46 PM »
Hello all,
I am proud to say i have finally joined the suzuki community and purchased my first 88' samurai today. It runs well, but the guy i got it off of said i probably need to rebuild the carburetor. With that said, i think I'm gonna put a new one completely on and was wondering what everyone here might recommend. I am looking to go with nicer than stock setup and wanted to know if anyone had a good recommendation of what carb to look into. I plan to rebuild it back up and take it off roading, but i will need to ride the highway to get to those off the beaten paths. Any help would be great, thanks
PM
Offline mrfuelish
  • 2862
Re: Help a new owner with some mods
« Reply #1 on: February 14, 2012, 05:29:52 PM »
Howdy, I would first start off with running a couple of tanks of gas through it with a can of seafoam added at each fill up and then see how it goes, I like the stock carb if it is working good. p.s. where ya from etc.?
Offline pm6214
  • 10
« Reply #2 on: February 15, 2012, 04:51:36 PM »
Hey i will try that, it takes like 7 pumps, 7 turns, probably 5 times to get it started from the cold. Once it gets going its good though. I can buy a rebuild kit for like 40 bucks but i am very mechanical, so i would have to have someone do it and than i would be at a 120 bucks or so, i was just thinking buying a new one might be better int he long run. Im from south jersey and am definitely a big wrangler guy, but have been partial to samurais since i was like 16. So you think it would be better to just rebuild the stock one, or is there a big jump in performance if i jump to a weber, by the way if i jump to the weber, which would you recommend?
Thanks for the response
PM
Offline Boxcar
  • 936
« Reply #3 on: February 16, 2012, 06:38:31 AM »
I would take the stock carb off, and If you love it, have it bronzed.
 Never seen any one have much luck rebuilding them.JMHO.
 For $99 you can replace it with this:
 The Yota carb from a early to mid 70 s 1200 Corola.
Its almost a direct fit and is jetted nearly perfect for your application.
Search Toyota carb swap for more info....Boxcar...
God Bless
