Help with 87 Samurai
  • 2172 Views
Offline BVRocker
  • 6
« on: November 09, 2018, 03:20:23 AM »
Need help I have a 87 samurai and while running it checking out other problems my samurai just quit... nothing works on dash temp and fuel gauge don’t show anything no light on dash.... but Engine will turn over with key but not start... my samurai is stock with 1.3 engine... I have check most of the electric connections and I have checked all fuses with a ohm meter...
When the engine died I lost everything to the gauge unit in dash...
Re: Help with 87 Samurai
« Reply #1 on: November 09, 2018, 01:46:05 PM »
Go to Ack's FAQ, download and print the wiring schematics and use them to verify you're getting power to the dash cluster - you're most likely not - use the schematics to find where you're losing the power supply.
Offline BVRocker
  • 6
« Reply #2 on: November 10, 2018, 06:03:47 AM »
What or where is. ACK’s
Offline BVRocker
  • 6
« Reply #3 on: November 11, 2018, 03:01:50 AM »
Problem found... bad connection on the fuse holder...
« Reply #4 on: November 11, 2018, 07:29:32 AM »
