How to remove ignition switch
  • 3514 Views
« on: November 27, 2010, 12:09:55 PM »
I have a 94 samurai. I broke the key off in the ignition, Does anyone know how to remove the ignition switch so I can get the key out? Thanks Dan
Re: How to remove ignition switch
« Reply #1 on: November 27, 2010, 03:42:02 PM »
BF Hammer ?
« Reply #2 on: November 27, 2010, 03:47:46 PM »
Tempting!!
« Reply #3 on: November 27, 2010, 03:52:31 PM »
I really can't remember, I took mine out from a Sidekick, I think there is a pin
that sort of looks like a bolt with a rounded head, that has to be worked out
with a chisel, if not that there might be a pin that you knock out, but like I said
it's been like 10 years since I pulled mine out, and I just can't remember, that's
what happens when you get to be my age, they say the 2 things that go are first
your memory, and I can't remember the other  ;)
« Reply #4 on: November 27, 2010, 05:46:19 PM »
Yeah, but your humor's getting better  ;D
« Reply #5 on: November 29, 2010, 05:01:05 PM »
Remove steering wheel.  Remove multi-function switch assembly.  Use a chisel to turn the 2 round headed bolts out of the top of the ignition switch assembly.  Remove ignition switch.
